Musical Fidelity A 3.5 no sound on right channel.
If both the preamp and power amp section of one channel are dead --I
take it the PRE out is dead when tested by itself ?
Then first check the power supply to the dead channel and make sure the tape monitor is off as well as the mute .
I cant find a circuit diagram either.
If its the volume pot then the wiper has lost contact with the resistance .
Normally wear would cause noise first , easily checked --ohm meter between pot input tab and wiper and check if the resistance varies .
If the power supply to the preamp is okay I would check all the active devices in the signal path as well as any switches the signal can be routed through .
