Music Hall CD-25 Cap values?
I'm in the process of modifying my Music Hall CD-25. I need some help choosing capacitors. I'm really a DIY newbie, so I'm not sure what's going on.
First: replacing 3300uF 42V caps with 4700uF 25V panasonics. Is the 25V ok? Should I look for something higher?
Second: there are 4 330uF 25V caps near the clocks. Should I go for 470, or 680?
Third: 2 47uF 35V caps near the opamps. What should I replace them with?
Finally: 2 10uF 50 v caps, also near the opamp. Again, no idea here.
I'm thinking either panasonic fcs or blackgates.
