Multiple S/PDIF outputs
I have been searching these days for the sound card with only digital outs. I am acctually quite fine with AES/EBU.
RME allows you to switch through the software commercial or professional out (S/PDIF or AES/EBU), at least it does on my curent RME interface Fireface 800. Software is the same - Total Mix for all, so I am pretty sure that you will have that choice with this card
RME: HDSPe AES
or
RME: Hammerfall DSP AES-32
One is PCIepress and other one is PCI based. Changing on your own from AES 110 ohm balaced to S/PDIF 75 ohm unbalanced is also very easy.
