Hello there
Was wondering what is the difference, what are pros and cons of multi-way and full range speakers? I want to replace speakers for my logitech z2300 sub, can't decide which to get. By the way do I need a new amp for loudspeakers?
Hi artazzzzz 🙂please, anyone? 😀
It's not easy. Putting it simply a full range driver needs to do the "full range" by itself so it might cause intermodulation distortion when doing bass & treble frequencies. Also a full range speaker generally won't cover the full range accurately, there are likely to be dips & peaks in the response.
Multiway speakers have their own problems. Time delay between voicecoils as well as problems with crossovers & level matching & again dips & peaks due to all manor of factors.
It's a minefield out there 😱
Recommending something is asking a bit much. It depends what you like in all honesty 😀 I guess you need to experience all these different things!
What music do you prefer
How loud is it at normal listening
Do you need to play loud, occationally
Which amp will you use
Which sound do you like
How big is your room
How big speakers do you want
I prefer electro, hip hop, rnb, techno, pop music.What music do you prefer
Normal listening is about 30-40% and nearly 90% at parties.
I have integrated amp into z2300 sub.
I like sound with rich midrange and midbasses.
My room is about 7x7 meters.
I need compact speakers, something like 10x10x10 inches max.
Fullrange problems -:
Low thermal power handling
Weak bass response and excursion-limited power handling
Beaming at high frequencies
Advantages
Cost
Simplicity
Size
Coherency
It's a case of being a jack-of-all-trades, but master of none.
In your case, I'd recommend a 2-way => 6" bass-mid + 1" tweeter.
Advantages
Cost
Simplicity
Size
Coherency
artazzzzz,
"I prefer electro, hip hop, rnb, techno, pop music.
Normal listening is about 30-40% and nearly 90% at parties......I need compact speakers, something like 10x10x10 inches max."
I'd skip the full range thing unless you can cross them over.
Do you runa pair of wires to your sub then from the sub to the speakers?
If you can, if you may want to try the full range thing, get a fostex 167e or a 207e.
If not then I'd recommend a 2 way with an 8", maybe an old klipsch kg2 even, but I think the small box will limit your choices, but a 6" and tweet will work also.
Rich midbass = moving air, or a sharp leading edge (from a compression driver). Maybe a pair of klipsch rb-75's.
Norman
Norman
thanks for your post!
well, I mean nto rich midbass, but midrange. Maybe I am not right, but I want not to have distortion at increased volume. How can I achieve this? I run 1 wire from sub to power supply, another to the control pad, from control pad to pc. And 2 wires from the speakers to sub.
Thats very low height
To make a small speaker take more power and stay clean you may need to run your main speakers through sub xo, to be high passsed active around 100hz
You definately dont need a delicate audiophile fullrange
Neither do you want small "hifi" speaker with 85db SPL or less
You need sensitivity and powerhandling
Dont know theres a kit with small PRO coax
Eminence Beta-8A is a close fit, but needs a tweeter and xo
Maybe some SB tweeter
A 10-12 liter box would work both closed and BR
Positive is a final 90db SPL, with BSC
If we join forces it might be possible to work something out
Depends on your skills and enthusiasm
But it might be my personal choise
How about it, should we start a new audiocom monitor
Might not be perfect at first, but who knows where it will end in a year or two
so tweeter+mid woofer would fill range from 50 hz to 20khz? right? I want sound with real quality, real loudness and long time playing 😛 basses are important. And those speakers would suit my sub and integrated amp 😀 !Right, well with a no limit size or budget it shouldnt be too hard, just imagine something 😀
what you mean?
what you mean?
Subs are different
I dont know your sub
Are there one or two subs
What I mean is, your sub and electronics needs to fit your choise
Well, you could also build something like this
Its fully documented, and comonents are available in EU
Might work better without sub
Zaph|Audio SB12.3 ~ SB Acoustics 12", Dual Midrange, 3-Way from Madisound
well, 1000 USD isn't nothing for me 😀. Is there any speakers I can build for ~100 USD? By the way I got 1 sub with 6" bass reflex enclousure, 120W rms. I want add speakers to them with some basses, good midrange and good tweeter (midbass woofer+tweeter speaker).
Excluding cabinet materials, more than a few. Able to play loud, with authority on the bottom -- you give up some finese.
A a pair of Mark Audio CHR-70 or CSS EL70 (made by MA) in Lotus or Conniston Changs (or even more dynamics in Maeshowe -- beta testers needed). These drivers also make excellent mid-tweeters if you need MORE.
or for more bass & levels, Pioneer B20 + tweeter in something like G Chang or HalfChang or CurvyChang
dave
- Multi-way or Full range?
