Good day all
I have some Mullard valves old stock not the new copies which have Foreign
written on them they look just like the original Mullards, has any one any idea were they were manufactured, they look as if they are made some were in europe.
Llan
Llan
Could you attach some photos showing the printed logos clearly?
All original Mullards were manufactured in England, but the brand was revived by Russian manufacture Sovtek who made a variant of the ECC83.
Also, which valves do you have and how old?
The first British-made Mullards were manufactured in 1926 (PM3 and PM4).
Inital Mullard 'production' involved re-labelling imported Philips valves.
... they look as if they are made some were in europe.
What, they don't have the square slavic look, or aisiatic facial features?
Are they fairer skinned than some of the alternatives?
What exactly are the differentiating physical features of a european-manufactured device?
And most importantly, will Brexit mean they have to be returned?
Mullard valves were part of the Philips group.
Most from 1948 have an etch code on them some where denoting Type, Date and Place of manufacture. This table is very helpful in understanding the codes. https://frank.pocnet.net/other/Philips/PhilipsCodeListAB.pdf
Alan
Alan
In danger of straying into UK politics there, you naughty New Zealander!And most importantly, will Brexit mean they have to be returned?
The ones I've seen that were labeled foreign were Philips from Heerlen, Holland or Valvo from Hamburg, Germany. All decent stuff usually. Though some of the old Mullard "valves" will work fine for a bit then break your heart. The filaments might blow. Or the filament will be fine but they'll go wonky and draw more, or maybe less current through the "active" section of the tube. Anyway, don't build a circuit around say two old rare tubes unless you have a dozen or so backups.
Steve
Steve
Mullard codes
Hello lads
Yes quite complex, well the code on my ECF82 is 4X5 and under this line is r5F1
and yes its a little r and the other ECF82 as no code on it other than 11 under the base between the pins , but looking closer at the structures they seem to be the same well made valves they look like Dutch or German?
Llan
Hello lads
Llan
Llan,
Yours is a Canadian Philips valve.
4X5 is an ECF82/6U8. Little r is from the Ontario Philips plant. Probably made in June 1955 (or 1965?)
See the table I posted in post #5 and confirm it for yourself.
You find a lot of Canadian 6U8 / ECF82s under various brands, but most are marked Made in Canada.
Alan
Alan
A number between the pins probably means not Philips manufacture, so you seem to have one Canadian Philips and one made somewhere else.
or they can be old, the old rimlocks had numbers between the pins, or the number of the base making machine stamped into the bottom.
Mullard codes
Well I managed to figure out what an imported Mullard EF86 coded BY3 plus D9J4 it was made in Hamburg, but I can not quite make out what KBA for a CV181 is and like wise a KB/Z for a CV1438 any ideas lads
Llan
Llan
Llan
Ummm, well Philips codes only become unified around 1948 as it says in the introduction. These are older types and most likely pre-date 1948 when there was no rational to the coding.
But, you are quoting the CV (Common Valve) codes and these start during the Second World War. KB is a specification the A or Z are manufacturer codes (usually - not always.) Look here please. CV NUMBERS AND UK MILITARY DATE AND FACTORY CODES – MULLARD MAGIC
and here
CV valves
So the CV181 KBA is a Blackburn (Mullard) valve and the CV1438 is an Hammersmith (Osram).
Not straight forward is it!
- Tubes / Valves
- Mullard valves
