Mullard 5-10 for guitar ?
So I built this some time ago which is basically a Mullard 5-10 with a few non-significant modifications like a 5y3 instead of EZ80, and a 6sj7 instead of EF86, although it was first built with the EF86 now I have added and rewired the socket for the 6sj7. Also is important to mention I have not added the tone stack, everything else is as the original schematic.
What are your suggestions if I want to plug a guitar with volume and tone controls, I was thinking using the spare 9 pin socket adding a single "high mu" triode for input --> tone-stack / volmue --> 6sj7 .
the 6sj7 as it is already has lots of gain.
The sensitivity with those is something like 10mV with the feedback circuit disconnected, I would play through it with the feedback disconnected first before doing anything.
After you try that there is the free noval socket you have so you could do a high mu dual triode: gain stage direct coupled to cathode follower-->tonestack/volume-->6sj7.......
good tip, I will try that, I didn't think of a cathode follower but it's a very good idea, similar to what the did with this
When I disconnect the feedback it get really noisy, hum mostly and sometimes it oscilates, so perhaps I will add a pot to reduce/increase the feedback as a feature.
Thank you.
So unstable with no feedback........Mullard does use quite a bit of feedback at 26db, maybe cut it back to 10db.
That circuit has a lot of gain even with the feedback. I was wrong earlier, the amp has an input sensitivity of 40mv WITH the feedback...........cut the feedback down to 10db and it should be a work for guitar:up:
The 5-10 does not have quite enough overall gain for guitar. But all you would need to add is a single triode gain stage like the first gain stage of any Fender or Marshall amp. If you look in Mullard's circuit book, you will find two versions of the 5-10 amp. One is a straight power amp while the other adds a tone control and volume control circuit to the input. Mullard's tone control setup is optimized for hifi use so using something like a Fender tone stack woudld work better for guitar. You could place it between output of the added triode input gain stage and the EF86's grid for the 5-10. The 5-10 can have the EL84's either pentode connected or ultralinear. Pentode would probably offer a more classic sound for guitar. The amp is capable of a lot more then 10 watts. The 10 watt rating is for very low distortion hifi specs. Most guitar amps are rated at distortion levels as high as 5%. The 5-10 is capable of 15 watts before really heavy clipping. Glad to see someone else using these classic Mullard circuits.
