MTX Thunder 3401
I get -70.4 volts measured directly acroos the speaker terminals..
I removed the NE5532 and the voltage drop to -50.3 volts..
All outputs test fine..
On the pads for the NE5532 i get the folloing voltages
Pad 1:-0.58
Pad 2:-8.32
Pad 3:0.00
Pad 4:-49.6
Pad 5:0.00
Pad 6:0.00
Pad 7:0.00
Pad 8:48.8
Does it appear that the regualtors have failed??
Replaced the regulators LM317, LM337,
Also replaced the TL072 that sits behind the RCA Jacks. The NE5532, R138,R139..
Replaced all the 10 ohm resistors on the preamp board..
I didnt plug the preamp board in yet i powerd the amp up and Got + -15 volts on the op-amps but after a min the regulators failed again..
Any ideas what to check?
Amp works with preamp board removed and jumpers in place..
I replaced all the TL074's and 10 ohm resistors on the preamp board..
Also replaced the TL072 on the preamp board
When i plug the preamp board into the main board amp has no output..
Any ideas on what to check?
