hi, i have a mtx 6500d amp with the outputs transistor burned, i change the 4 transistors with the same model, but the amp has a burned resistor near to the outputs, is the R148 and idont have the resistor value to change it.
so anyone have this value??
and other doubt, i dont have anymore SMD resistor to change the 6 burned 0.22ohms resistor from the outputs, so can i change these SMD resistors with 0.22 ohms standard size resistor? i will use 1/2 watt standar resistors, i dont have problems with the space, but i dont know if i can do this.
Thanks¡
Thanks¡
