Hi, I have a problem with a MTX 4250D, it's powering on but there is a lot of distortion at the output from the sub. I already changed the output transistor and resistors. Someone has an idea?
Then it's probably more like the 6500D. Can you post a photo (or email it to me) showing the parts that have been replaced?
babin_perry@yahoo.com
Have you confirmed that you have both positive and negative rail voltage (on the output transistors) as well as positive and negative regulated voltage (on the op-amps)?
