Mosfet power amp Vbe multiplier
I would like to know: do mosfet power amps also use a bjt vbe multiplier attached to the heatsink for thermal tracking?
I thought with the mosfets having a neg temp coefficient, a vbe multiplier attached to the heatsink wouldn't be necessary?
Actually a negative temperature of Vgs with temperature makes HS attachment of some kind of compensation necessary, as drain current will rise with temperature for a given fixed bias level. It's a positive tempco you're looking for, as is exhibited by lateral fets at modest bias current levels (a couple of hundred ma), and for vertical fets at bias current levels that blow up the bond wires.
