Mosfet Output Stage Temperature Stability
The one and only
Joined 2001
Excerpts from the FAB Notebook:
(Since there is more than one thread pondering the issue)
Running Mosfets without degenerating resistors or complicated biasing
schemes is not all that difficult. As I have said elsewhere, it takes
adequate hardware and a little patience.
Not all that long ago I did a thumbnail analysis on power Mosfet current
sharing without degeneration. I matched up a group of IRFP Mosfets with
varying degrees of Vgs match at 25 deg C, 1A and put them on the same
sink and ran them with a fixed Vgs for an initial 1 amp current until the
sink reached 50 deg C.
At 50 deg, the current through each had drifted up about 30%, or 1.3 A.
The parts matched to 2% (about 10 mV Vgs) at 25 deg showed about
a 5% match at 50 deg.
From this you can conclude that reasonable matching of Vgs at room
temperature is adequate to hold a match at normal operating temperatures,
and the drift with temperature, while significant, does not necessarily lead
to thermal runaway.
In this case you could adjust the initial bias at 75% and let it warm up.
Don't try this with Bipolar devices. There is more than one manufacturer
who has learned that the hard way...
