Monoprice 8 inch Kevler Speaker Amplifier
as you may see there's a tweeter placed in the center of the kevlar cone - it's called concentric or coaxial- and the crossover network is there with the purpose of filtering the signal for the two different speakers. It also plays a role in equalization and level matching between the two.
And, of course, it is calculated for installation on wall.
So if you "exit" from the infinite baffle configuration
( and on wall it's a "half space emission" type) as you would intend to use it in a regular box, you'll find that you'll have to fight with BSC ( baffle step compensation). So you'll have to recalculate the filter : bigger inductor on the woofer, so probably different level at crossover frequency and it requires a basic but solid approach to this kind of matter.
