Monitors, eq's and power amps
Hello. I'm wondering if it is possible use 1 dual band eq (Behringer Ultragraph Pro FBQ1502HD) with 2 power amps (Crown XLS 1002) and 4 passive monitors with 1 line level monitor out coming from my powered mixer (Yorkville) Thanks!
That 15band EQ won't be of much use for feedback control only general response shaping but otherwise this can work.
You will need a Y cable to split the monitor out signal from the mixer to both inputs on the EQ, then connect the L output of the EQ to input 1 of the first amp and R output of the EQ to input 1 of the second amp. Now go into the setup menues of each amp and set them for Y input, that sends the signal from input 1 to both amplifier channels. Connect the speakers to L and R outputs on both amps.
