I just acquired a Bryston 10b after a long search for an electronic XO. I wanted analog, high quality and discrete components. And there aren't a ton of choices.
Once receiving it. I downloaded the schematic and popped the cover. Right away I notice that there are 8 100uf electrolytics directly in line right at the outputs. There are also some small ceramics in the signal path right before the high pass resistor array ( I presume the switch shown in the top right is the 6/12/18dB selector labeled N1/2/3)
It is the standard model, not the Sub. it is the balanced version.
I'd like to upgrade whatever components I can to increase performance. Aside from the components I noted, I'd also be grateful for other suggestions.
Part of the challenge is this unit is only about 2" high, and those electrolytics are on top of a board so there's limited room. One option I considered was to move the PS board to an external box, which would open up room.
Any and all suggestions would be greatly appreciated!
I wouldn't worry about the 100 uF electrolytics: their impedance at audio frequencies into power amplifier inputs is negligible so any nonlinearity would get lost in the noise.
Which small ceramics concern you? If it's the 220 pf / 47 pf /10 pf jobbies in various feedback loops then they're most likely NP0 or C0G, which are stable and non-distorting. I use that type myself in preamp inputs to keep RF gunge out (and Lordy do I have a story about that).
Why? A close read of the schematic indicates the 100 uF parts are most likely bipolar.Better to use Nichicon UES 10uF instead of the 100uF parts.
Agreed, I have a few myself. However the Bryston boys weren't in the habit of using whatever fell off the truck 😆 so one could imagine the part is reasonable.
Not going to argue with you, not a Bryston fanboy. Just answering the question from CTS90.
Neither am I, but I gotta recognise they're not fools.
Anyway, tldr to answer his question I'd guess the parts on board are competent.
I don't doubt that the unit was built with perfectly adequate components. And a number of the components would not be impacted by any sort of "better" option. And while I'm no electronic engineer, having seen many schematics and looked at lots of equipment, I know manufacturers of higher-end equipment try very hard to keep any sort of capacitor from the signal path and when it's necessary, they use upper end film caps. I have swapped caps many times in lots of different equipment and have experienced the benefits.
I know next to nothing about active crossover design aside from basic function. And the circuit layout looks very similar to other low-level signal devices. So that brings me to;
-I have no idea from a design perspective why those caps are there.
-I know from experience and looking at the practice of others that caps in the signal path are worthy of avoidance.
-You don't see much in the way in upper end designs of electrolytics in any signal path.
-Film caps in my experience always sound better than electrolytics.
What I'm attempting is to expand my knowledge base and understand the why's. I could just move some things around and stick film caps in there. But then I would learn nothing.
Thanks for whatever you can share.
- Analog Line Level
- Mods on Bryston 10B Crossover
