Modifying Ebay Boost Converter for Tube Amp B+
Here's a boost converter typically found on Ebay:
Product says: 150W 8A DC 8-32V to 9-46V 12 24 36 step up BOOST converter Laptop pc car power
Can anyone please explain what's preventing me from doing these:
1. Replacing the diode and output capacitors with higher voltage rating
2. Changing the feedback voltage divider ratio by getting higher value trimpot
to obtain B+ as high as 250-300 volts?
I plan to supply the module with 12V from ATX computer PSU. The module must be able to supply 100-200mA of current.
The one i saw that fits the requirement is a one-off item, and not as cheap as these mass produced converters. Or perhaps my Ebay keyword imagination is lacking? Nixie tube power supplies can reach the voltage i need but judging from the puny inductor size, i dont think it fits the current requirement part.
In my experience with Nixie tube supplies is that they are very noisy, as in a high pitched squeel audible from a few feet away. Dont think i would want to try one in an audio circuit. Output current would also be very low, i doubt they would do 100ma.
most important: you have to replace the mosfet switch with one that can withstand the voltage (vout + vringing) but still support the same peak current
usually HV mosfets have higher Ron, producing more heat - bigger heat spreader
you also have to redesign the snubber on the mosfet (R/C/D)
and finally boost converters over 7x get very inefficient - again more heat
I can suggest an alternative 'ebay type' product that hardly needs any modification - based on a car inverter plug-in product. See thread link for discussion and link to my info on that product and mods.
Any use for laptop chargers 15v - 19v for pedal supplies or amp builds
It's going to be nigh on impossible to convert a simple boost circuit to get 12V to a few hundred volts with many watts of output - because of the fet and diode duty cycles needed and the impractical high voltage and high current requirements for parts.
Yes i gave power inverters a thought as well but ditched the idea since they work at 50-60Hz which is harder to filter (in SET amps, most likely you'll still have to get a choke). Yours seem to work at SMPS freq though.. only drawback is the low watt output. 5 watt won't cut it even for mono SET amp. I think yours are not unlike nixie tube supplies.
