hi,
i had posted similar at last time with only two pair transistor modified symasym amp. this time i had tested four pair output transistors 2sc5200/2sa1943.
i just need to know is this correct way to adding four pair of transistor in this amp?
i have tested but to me its woking fine. should i drive it this way?
i have posted the modified design virsion only at output driver.
pls need sugestion on this amp.
thank you
michael
thank you
michael
space2000 said:oh no,....no one to help me......
pls.....pls....pls.......................
Ask Mike Bittner directly he would be able to help you. Have you tried?
Yes you can have four output pairs and in case you wonder one day, yes, you can use twelve output pairs.
