GGreetings, has anyone got a copy of the mm only el cheapo vinyl addicts phono preamp as a) i wont be needing mc
b) I'm a vegie when it comes to schems
c) will be getting help building it
d) may help me to understand without unneccesary info
cheers fergs
cheers fergs
This looks simple and cheap enough, I need a phono preamp for testing purposes of my DIY turntable as I build it. What is the quality of this circuit like compared to the cheap ones available at he moment.
Check out Mint Tin Thread - easy to build
fergs1,
Check here for a simple to build version. I designed a PCB based on an ElCheapo that would fit in a mint tin. Is dead quiet and sounds very good although, expect will sound better with higher B+ (two 9v batteries) and better output capacitors (small poly, teflon or PIO) - next version. Let me know if you need help
Cheers -ALBQ
http://www.diyaudio.com/forums/showthread.php?threadid=79545
fergs1,
Cheers -ALBQ
Re: Check out Mint Tin Thread - easy to build
What do you mean by "dead quiet "?
It is really dead quiet?
I never heard a "dead quiet" anything(audio). I have head 'very quiet but not "dead quiet".
If it is really "dead quiet",I think a will make one.😀
ALBQ said:. Is dead quiet and sounds
Well... quiet
jaudio,
Well.. just a little hiss with my ear up against the midrange horn of my Klipsch LaScala with the volume turned up all the way. So, i'd say its quiet... 😉
Cheers -ALBQ
jaudio,
Cheers -ALBQ
- Analogue Source
- mm only 'el cheappo vinyl addicts'phono schematic
