HI
I´m playing with MathCad 8 free demo. Enclosure is similar to Ariels but with MT Vifa PL18 configuration. Infinite Baffle SPL is nice with gradual rolloff.
Driver measured Fs: 38Hz, dip is at at 35HZ. Also first peak from Acoustic Impedance graphic is at 35Hz, and I really don´t know if this result is fine.
Thanks in advance for comments.
JC
JC
I believe the dip conicides with the impedance rise of the driver. This is normal. What you want to be concerned with are the ripples higher up. Here's a thread with MJKs explanations.
http://www.diyaudio.com/forums/showthread.php?threadid=25388
Hi Tinm8ter
Thanks for reply.
In impendance graphic first peak is at 35Hz
Driver Fs is 38Hz so it´s 3Hz lower. Any problem?
TIA
JC
Thanks for reply.
TIA
JC
