Hi, needs help for my Mark Levinson #23 shuts itself off after 3 sec, wish someone could tell me where and how to start looking for short.
Hello,
Is your amp allready open?
My power supply is overheated and I'm trying to fix it.
But there is a resistance burned and I don't now how many Ohm it was.
Can you make a photo for me from the power supply print?
It's the one at the front panel.
Maby you can see what for resistance it is.
It is the one above the on/off switch.
There are three components right above the switch.
2 orange capasitors and a resistance.
Could you please help me?!
greets Julian
vosjulian@hotmail.com
greets Julian
First you have to unscrew the side panals and front plate.
After that you can unscrew the 4 srcrew's in ease corner.
Then you can pull the front plate over.
Howard Lan said:I'm having problem to open the front panel.
In that case it's highly recommended you get someone qualified to have a look at your amp.
