MJL4281-4302 Matching
I am building a P3A so I got some MJL4281s and some MJL4302s. I get good HFE matching between transistors of the same type (npn or pnp), but there is a quite big mismatch between PNPs and NPNs. Is this normal?
And the same thing happens with MJE15035 and 15034...
There are always large differences in Vbe between NPN and PNP. This is quite normal, and makes little difference in practice.
However, as Andrea comments, if you parallel a number of NPN devices (or PNP devices) then like devices should be matched.
This matching must be done for both Vbe (most important) and beta (less important).
Vbe should be matched within 1mV at the same ambient temperature, and for a current through the device which closely matches the bias current which will be used in the amplifier.
Beta should also measured at the bias current, and should be matched within about 5%. 0R33 emitter resistors (or higher) will ensure that current sharing is almost identical.
Hugh
I just noticed the same thing with my MJL21193/21194 transistors. At an Ic of both 50mA and 100mA the hfe of the NPN's were around 50 while the PNP's were over 100!
A quick look at the datasheet tells all. For mine, at lower currents the PNP devices clearly have much higher hfe than the NPN's. They start to even out around 1A, but they still don't look like very good complimentary devices. Hmmmm, I wish I had studied the specs a little more before I ordered them. Oh well, they'll do fine until I can get some MJL4281A/4302A's 😉
OK, the point is: don't worry about matching the NPN's to the PNP's. As long as your driver stages are capable of supplying enough drive current, the the actual hfe value is not too important. Just match the LIKE devices and you'll be fine.
Matching the beta between NPN and PNP output devices is useless except when the drivers and pre-drivers are also matched
Actually, the values to match are beta_predriver*beta_driver*beta_out between high and low sides, this is in order to make both sides have the same *total* current gain [as seen by the VAS] and reduce THD and crossover distortion
Particular gain of each device is not important at all since there are different devices in series
Matching the betas of the output devices of the same polarity is useless since it has little efect over current sharing
Question about "matched" power transistors
I recently bought some matched pairs of "Genuine" MJL4281A/4302 off eBay. They are identical to some samples I got from ON Semi, so are prob'ly not fakes.
The seller says he used "curve tracer" and "300mA", but that was all he gave.
Each transistor of the pairs had numbers written on them:
The 4281's were marked "136.1 and "136.3"
The 4302's were marked "184.2" and "184.6 "
I'm new to the realm of curve tracers, so I'm not sure what the markings are(Beta?).
Can anybody here tell me? (The seller's english isn't very good).
Thanks,
-Chas
Some say PN mismatch is the primary source of distortion in class B (dear I say class AB) output stages.
Some say PN mismatch makes no difference as NFB sorts it out.
Some say PN mismatch makes the amp sound better as it creates more H2.
I guess all are right in a way but I know what I'd do 🙂
........................Vbe should be matched within 1mV at the same ambient temperature, and for a current through the device which closely matches the bias current which will be used in the amplifier.................
This is the most important by far when using devices in parallel.
It also applies to mosFETs, where Vgs must be selected for equality.
