MJ15026 and MJ15027
I am new to this page, but IMHO, I would try the MJL1302A (PNP) and the MJL 3281A (NPN). They are from ON Semiconductor (used to be Motorola). These units sport the following characteristics:
The MJL3281A and MJL1302A are PowerBase power transistors
for high power audio, disk head positioners and other linear
applications. :yes:
15 AMPERE COMPLEMENTARY SILICON POWER TRANSISTORS
Vce = 200 VOLTS
Pdiss = 200 WATTS
• Designed for 100 W Audio Frequency 😎
• Gain Complementary:
Gain Linearity from 100 mA to 7 A
High Gain — 60 to 175
hFE = 45 (Min) @ IC = 8 A
• Low Harmonic Distortion
• High Safe Operation Area — 1 A/100 V @ 1 Second
• High fT — 30 MHz Typical :bigeyes:
I especially like the 30MHz gain-bandwidth figure!
These units are used in some of the better high-end amplifiers.
try www.onsemi.com and go thru the pages to the Bipolar Power section. Best of luck!
