Mission FS2 replacement subwoofer
Hi all,
Hope this is in the right forum and if so, someone can help me out here with a legacy sub.
I have an old Mission FS2 AV sub/amp which I want to get fixed, 😱 dont laugh!!!
Purchased on ebay in the last year, It was cheap and filled my needs for a PC 2.1 sound system for gaming.
I use it as a stand alone sub, running an LFE pre-output from my Onkyo CR-525 mini hifi, It worked great :-(
So, It needs a replacement sub driver, The one I pulled out of it (decayed foam edges) was an unbadged model "AP170MN2 10237FT 238/00".
Is this the even original speaker?
One site mentioning this model: Translated
It seems to be made by Audax?
They have no record if this exact model on the site, but there are similar ones:
AUDAX, LA PASSION DU HAUT-PARLEUR
Regarding the specs for the unit, This is all I can find on the actual subwoofer.
Frequency Response: 48 Hz - 20 kHz
Sensitivity: 86 dB
Impedance: 8 ohm
Woofer Size: 6.5"
Subwoofer Power: 55 Watt
Any help pointing me in right direction for a compatible replacement (UK & GBP) gets a big shiny internet blue peter badge! And many kudos of course. 😛
Cheers
