does anyone know what drive units mission use in the 780s
mission would not tell me! mmmmmmmm
who make them and what model are they?
tar..............
tar..............
If you mean these:
The tweeter should be a Vifa D19TD
I am not so shure about the woofer, but i belive i heard somewhere that it as from Peerless in India
This may not help... I have a pair of Mission M70s. The mid/woofer drivers are mission proprietary I believe (the tweeter is a Vifa). Can you open them up and post some photos of the back plate / any other markings if not obvious?
David.
David.
The 780, IIRC uses a custom built midbass driver.
I believe they were built by Audax. I ditched my pair a couple of years ago but remember the code on the magnet being very similar to the Audax style of code.
Probably wrong but I vaguely remember AP130 xxx something or other!! Plastic frame and similar Phase plug as well.
I remember being a little disappointed when looking...
Good Luck!
Steve
Good Luck!
Steve
This is getting confusing, in fact there were two different 780s - the one pictured above from the '90s and the ones from about 3-4 years ago described by stee-b which did, indeed use a custom ('keraform'?) Audax unit. Which ones do you mean?
