Miro PCM1704 (JLSounds/York stackable version)
SALE OF THIS ITEM IS WITHDRAWN
Miro USB interface stack PCM1704 DAC board for sale.
A pair of PCM1704 with one white dot => J graded chips on the board, and these are very difficult to source these days. These are recycled chips from a reliable seller, removed with proper care. They are not bought from random sellers in Ali or ebay. They work properly and nicely.
What you need to provide :
1. Chassis, wires, connectors etc
2. You will need to give it PSU with rails +/-5V (Analog) , +/-5V (Digital) and +/-10~12V (IV Op amp supply)
3. Compatible USB-I2S interface board that can be stacked on the DAC board, which are not offer in this sales. The two such devices are :
http://jlsounds.com/i2soverusbFIO.html
and
[IMG alt="eclipsevl"]https://www.diyaudio.com/community/data/avatars/s/104/104467.jpg?1709846720[/IMG]
Thread 'USB UAC2+HID Multichannel input/output interface York'
2024-06-05 4:19 am
Hello DiyAudio community,
TL;DR: This is a USB transport for audio output (up to 8ch) and input (2ch for now) and user device control (e.g., DSP management) from PC (MacOS/Linux/Windows) thru I2C/GPIO. Including bootloader for remote firmware update, flexible device configuration, HID interface, multiple audio output options, integration with SigmaStudio (simultanious audio playback and ADAU DSP configuration). Compact module available in USB-C and USB-B versions.
So, the story started when I needed a USB transport for audio output and another channel for device control, such as for...
  • eclipsevl
Board fully populated with good quality caps eg. Nichicon KZ and FG, Wima Mkp, Panasonic acrylic caps, Amtrans AMCH copper foil etc
The IV Stage has a pair of AD811 op amp with heatsink mounted. Design is posted by Grunf, and discussed here:
grunf
2023-01-11 6:54 am
First, let me introduce my DAC, some have already seen it, but for those who haven't, it's a classic old-school DAC with DIR9001 as a digital receiver, PMD100 digital filter and 6 PCM1702s, three in parallel for each channel. The output current of 3 PCM1702s is 7.2mAp-p max. The power supply is given the greatest care, the PCB itself with DIR9001 has three ADP7118 regulators and they are the only IC reg. in the DAC. Other regulators, two +5V for PMD100, +/-5V for PCM1702 and the new +/-10V for AD811 are low noise shunt regulators, slightly improved, made according to Mr.Walt Jung's article...
Payment by PAYPAL FF only please.
DAC + shipping registered & tracking = xxx USD or preferably xxx SGD (Singapore dollars)
Again, please note that the USB-I2S interface board is not included in this sales.
