Mirage M1
I am looking to clone a pair of older Mirage M1 speakers. Does anyone have any info on these things (make/model of the drivers)? I looked at Mirage's website to get some info, ie the crossover points, and number/sizes of the drivers, but not enough info to build a set. Any help would be great!
Joel
I called mirage today. They stated that all the drivers used in the M- series of speakers were their own design and not available anywhere. I wonder how the speakers in the avalon clones would work in M-1 cabinets?
Any thoughts?
Driver size's and x/o points
I managed to find this on mirage's site:
M1si
2-1" pure titanium hybrid tweeters
2-5" poly-propolene midrange/fullrange
2-8" woofers with poly/carbon filled treated cones with 1.5" or 38mm voice coils
Crossover points are listed as 300Hz and 2 kHz
http://miragespeakers.com/PDFs/classic_manuals/M-si/M1-si/M1SIbrochure.pdf
copy and paste this link into your browser and you will find detailed info including a cut away of the enclosure. Good Luck!
Hmm... Where to begin...
Having been around API when the original M1's were in production I think I can provide you with some info on the design.
All the drivers from the original M1's were built in-house. The tweeters were a direct rip from the Energy 22s (cloth dome design) and the Image line (thick plastic oval faceplate). If you can get a pair of Image tweeters you're well on your way. They were awesome drivers.
The mids were 4" in diameter. Nothing special about them. A pair of Seas 4" mids would be good replicas...
The woofers were of long<er> throw design. Memory is pretty grey but I recall Qts on them were ~0.4 - 0.43. We always had to keep costs down so no cast baskets or other fancy thinks like that.
The cabinets were quite a piece of work. the woofers were in separate enclosures; the front sharing area with the tweeters. The mids were in their own enclosure made of sonotube-like tube with a customized 1/2" particle board brace running front to back. There were two guys dedicated to building the M1s. They woould get 2 pair done per day.
The woofers were crossed over at two different points - the back at 200Hz and the front at 400Hz. the Xover used a combination ferrite and air core inductors (ferrite for the woofers) and electrolytic/poly caps.
More as I remember...
Mark
