Hello, I am currently in the throes of putting a Raspberry Pi and DAC into an aluminum enclosure. I was wondering what would the minimum gap / dimensions of gap that i would need in the aluminum for the wifi connectivity to still work ? hifix.
My apologies for the vague answer, but... For 2.4 GHz WiFi the wavelength is almost 12.5 cm, so I guess you would need a hole that is large compared to 12.5 cm if you want the degradation of the WiFi reception to be very small. If your Pi is right next to a wireless router, you can probably get away with a much smaller gap or hole, because you can then allow considerable attenuation of the RF signal without losing connectivity.
Thank you for the feedback. Its much appreciated.
The cutoff condition for an aperture is λ > perimeter: it then functions as attenuator.
However, respecting perimeter > λ does not guarantee a good transmission, it depends on a lot of other factors.
Note that the aperture can take many forms and shapes: it can be a simple slit, straight or sinuating, it could be an isolated panel or part of a panel, etc
A slot half a wavelength long would act as a slot radiator, so would probably let more through than a shorter or longer slot.
Thank you all for the replies.
I will try cutting into the aluminium. Should that be unsuccessful, the external antenna might be the go.
Would the dimensions of the slots on the top of this casing (i hope the pic shows up) approximate that of a slot radiator ?
The possible problem with an array of slots is that they could form a diffraction grating, so RF gets through but only in certain directions. You will need to experiment.
slots can be tiny width and they will leak some RF.
That example case has lot's of different slots.
The ventilation slots are wide.
The slots where the face plate and back plate attach to the case.
The slots where the upper and lower halves fit together.
For a slot to not pass RF there must be an electrical connection ACROSS the slot.
anodising and paint are not an electrical connection.
What about placing 4 washers between the backplate and the case?
Adjust the thickness of these washers to adjust the gap in the slots. Worth experimenting.
1mm might be enough. Would 3mm be too ugly?
The washer idea is brilliant. Thanks for that and the insight into RF blocking.
This (the washers) as a first step could circumvent the cutting and drilling.
1mm - 3mm is definately acceptable.
An external antenna is the only way IMHO.
This would the last resort.
- Design & Build
- Construction Tips
- Minimum Gap (in aluminium) for Wifi transmission ?
