nanoDIGI 2x8 B
nanoDIGI 2x8 all digital DSP with SPDIF/Toslink input and SPDIF outputs for up to 8 x Output channels.
I recently purchased this unit so it is just about brand-new and is in perfect condition. I'm selling it due to a change of plans.
I am selling for £140 plus £5 postage. This price includes the software on a CD which costs $10 extra if you had to buy it.
Contact me by phone (01637) 875356 or email
Some extra information available on the link below.
miniDSP nanoDIGI 2x8 Boxed Digital Signal Processor: Amazon.co.uk: Musical Instruments
The nanoDIGI 2x8-B is a palm size all digital processor boxed in a grey anodized aluminum enclosure. Featuring the well known flexibility of the miniDSP brand, the nanoDIGI makes affordable high end digital processing by using existing 3rd party high end DAC units. On the input side, either SPDIF or Toslink (Optical) input are available and selectable from the software or IR learning interface. The internal sample rate converter will take care of adapting your digital input signal to the core operating sample rate frequency (44.1kHz to 192kHz). Finally, the four transformer isolated SPIF outputs allows up to 8 processed audio channels to be sent to your own DAC or SPDIF powered amplifiers.
On the processing side, the nanoDIGI makes full use of its DSP to provide a wide range of processing blocks for most common applications. As per the miniDSP concept, its is the plug-in which defines the ability of the platform and therefore its sampling rate. From 96kHz to 192kHz configuration, the nanoDIGI is a unique affordable, flexible and palm size processor.
Features
28/56bit Digital Signal Processor for higher audio performance
Asynchronous Sample Rate Converter (ASRC)
Real time control over USB
IR learning feature with any remote
5-24VDC 2.1mm round barel
Low power, Small size (only 75x75mm)
Features
