Hello
I'd like to order a MINI DISSIPANTE 3U, however, the webpage does not show UMS heatsink substitution..
Thank you
Thank you
Look at the regular width DISSIPANTE 3U, theyre listed below. Are they any different than the ones on the mini??
You're corect, but when you click on it, you only have 4U and 5U options. Shouldn't be listed in the 3U, but I think it nice they let you know it's available if you upgrade to the 4U case.
It may be a good idea to make a mini 4U so that pre-drilled sinks can be used. I for one like the smaller footprint design, regardless of height.
