Mini Class-A SE amplifier needed
Hello, I am trying to drive my minimus-7 monitor speakers with something better than these cheap IC amplifiers. Size is an issue, trying to squeeze the circuit into a small box with not so BIG heatsink (mayby with a fan too)
Would you recommend the next schematics? Or what else?
3 - 5 Watt Class-A Audio Amplifier Circuit Diagram | Circuit and Wiring Diagram
http://projectcircuit4u.blogspot.com/2009/07/5-watt-class-audio-amplifier.html
The power is quite low but the transistors are small too, which make the amplifier quite small in size.
Class A SE is inherently wasteful and it is the worst choice possible if heatsinks have to be kept small.
But for class A (not SE), the JLH is indeed probably the best alternative regarding the performance/complexity ratio.
If you are in stereo, you can try my trick of the SE regulator chip amp: it has a slightly improved efficiency compared to a regular SE.
