Bought these a while ago, will never use the all. Plessey Mk4 & MK7 as well as Cannon Multi Way connectors, most NOS, some used. Some are complete with all washers etc, some not, but all are useable. Ideal for connecting valve/tube amps and power supply's. Each has a chassis mounting socket and accompanying plug. see pics.
Specs are 250v to 2.5kv, see datasheet attached. Not 100% sure of the 2.5KV rating, but they should be ok for a good 500v.
First up 6 12 way, looking at datasheet good for 5A. Two complete with caps - £7 each. Three used - £5 each. One missing a cable strain relief. - £4.
Two big 9 way (19A) with caps, one with cable grip £7,one without £5. One big 6 way complete - £7
Two 3 way (19A) with 90 deg "elbows" - £4.50 each.
Lastly two big 4 way (60A) with caps complete, one with plug - £7, one with covered chassis socket & strain relief - £8
For postage drop us a PM, Andy.
