Midrange to range 200-2000 Hz?
Hi to everyone.
Need midrange in this range.
High SPL, nice sound and low distortion.
I have got pair JBL 660 GTI. Very low THD in 200-2000 Hz I see in review.
But I also saw a couple of other candidates
AE TD6M
Purifi PTT6.5M04-NFA-01
Purely theoretically, based on their high price, I will introduce a couple more candidates.
BLIESMA M142T-6
Accuton C168-6-990
18sound, Nd430
Today, maybe little bit old technology, but still excelent
Thanks.
Thanks.
Thanks.
Lowther DX 65 if in front horn, or 15 ohm 8 inch dx4 Lowther on open baffle aka Basszilla.
Thanks, but horn is not appreciated here, too much large of the size, need compact.
What would you define as ‘high SPL’?
Not for stadion or for open stage, but just enough. Without digests and numbers. I added it only because I often, and for a very short time, listen to heavy genres, you know, and then for the adrenaline to start flowing, you need to add more wood to the firebox. But this is one or two compositions in a row, no more, then a pause is needed.
If I might suggest it: download a SPL meter app on your phone, put it on measure with peak hold at about one meter from the speakers and go listening at your loudest. Report back here if you tipped the 110dB.
Hi to everyone.
AE TD6M
BLIESMA M142T-6
Accuton C168-6-990
I'd limit the passband to 300hz.......at 200hz you're in mid bass territory and better served by a more visceral driver with surface and linear displacement. You don't want a critically damped cone here but instead a high Q damped enclosure.....let the light weight cone do it's thing
Reactions: GM
