I have some midrange speakers that I'm trying to design a ported box for. I'm a bit confused about what frequency I should tune the port to.
Another question is: when tuning the box in WinISD, should I aim for a flat graph or a peak? The aim of the speakers is not SQ but rather loudness. but I am unsure if I am better off with a flat response or huge peaks at around 250 Hz (that's what I was able to reach with a non-negative port). I have atteched a picture of the "peak" respons box
Depends on the needs of the app, so which driver brand/model, T/S specs, intended app and your performance goals?
Well, the goal is to be loud, and that's why I'm unsure of the graph because they are loud, but will the sound be extremely trashy to the point where it is unusable with a huge peak like that? They will be going into a car.
I'll have four TT-008 from TT-technology in the box.
with the T/S specs:
with the T/S specs:
- Resonant frequency (FS): 108.885 Hz
- DC resistance (RE): 3,7Ω
- Electrical Q-factor (QES): 0.913
- Mechqanical Q-factor (Qms): 8.038
- Total Q-factor (Qts): 0.82
- Equivalent volume (VAS): 10.730 liter
- Moving mass (MMS);13.243 gram
- Sensitivity (SPL): 93.681 dB
- Effective piston area (sd): 21.642 cm2
I tried a sealed box, and it gave me a more flat response, and that's why I was wondering which design would be better for my use case (being loud). Flat or curvie respone?
- midrange speaker tuning frequency
