Hi all.
I've got a musical fidelity x-p100 pre amp here to fix.
Fault - primary winding on the toroidal power supply has gone open circuit.
Issue - unmarked transformer, nothing at all.
So, is anyone willing to share what the output windings are on this beast ?
or the voltages on the 5 pin plug/socket.
Thanks.
Thanks.
Ok, never mind.
Opened the preamp and found the voltages marked on the circuit board.
For future reference;
transformer is ~ 20watts, and is potted into the lower half of the power supply case with potting resin, so unless you really want to, it'd be easier to replace the entire assembly with a new case etc.
71 - 0 - 71
0 - 11
pin1 71vac
pin2 0vac
pin3 71vac
pin4 0vac
pin5 11vac
interesting side note, the preamp circuit board is set out to accept the nu-vista tubes.
in the tubes place are ztx transistors.
so without digging to far, looks like it could be a pretty easy mod to turn a x-p100 into a nu-vista pre..........
71 - 0 - 71
0 - 11
pin1 71vac
pin2 0vac
pin3 71vac
pin4 0vac
pin5 11vac
