Anyone used the FE166En in a metronome? I just got WAF Approval for a Metronome of the FE167 Dimensions. Since the 167 is no longer available i thought about using the 166. What would be the dimensional changes for the 166?
The FE166 is not really suitable for a met. FE166 may look the same as an FE167 from the front, but they work in completely different boxes. The FF165wk would be suited to a met, and extrapolating from FF85 and FF125wk should give at least an incremental improvement over the FE167
dave
dave
Bummer, looks like the met tables are only showing drivers that are no longer available of extremely expensive. Any suggestions other than the Met that leave a small footprint yet are tall floor standers? I'm hooked on a full range single driver. Trying to keep the driver cost under $100 each if possible. unless someone has a set of FE167's they would like to sell or trade for a small 6EM7 amplifier.
how tall are you thinking?
as Dave noted, while initially concerned over some technical aspects of the new models, our experience with 2 of the new FF---WK series* would suggest that the 165 would be a quite suitable candidate for FE167E designs, and at $80 each (before taxes/shipping) certainly meet the budget -
* will still need that traditional break-in period
We do know that FF225wk works in FE207 met (with a vent change), i suspect that FF165wk will work in FE167 met.
dave
dave
I am trying a Metronome with the FE166en with the following dimensions,
S0 = 65 in^2
Sl = 11.7 in^2
LL = 56 inches
Zd = 28 inches
Stuffing = 0.25 lb/ft^3
Vent Dia = 2.75 inches
Vent length = 2 inches
Hoping it to come out well.
S0 = 65 in^2
Sl = 11.7 in^2
LL = 56 inches
Zd = 28 inches
Sure Chrisb.
I did some more tweaking with the dimensions as below today,
Closed Area = 6.5 sq. inch
Open Area = 65 sq.inch
Taper Ratio = 10
Line Length = 56 inches
Driver offset = 28 inches
Vent area = 6 sq.inches
Vent length = 1.17 inches
Tuning freq = around 58 Hz
Stuffing Density = 0.22 lb/ft^3
Below are the simulated results with the LA
Taper Ratio = 10
Also please note the first several comments in this thread regarding the suitability of the 166 in this design. It'll "work" of course, but the driver could benefit from more LF gain than the Met might be able to deliver, and EQ can only go so far before the driver's excursion limit will become a major factor.
Thanks Chrisb for your suggestions. Will a simple ML Straight Line TL be a better option with the FE166? Pls. suggest.
The conventional thinking for that family of drivers has always been that a BLH / labyrinth of some sort will yield most extension and "weight" to the bottom end. Of course there may be other opinions on that.
The "best" sounding example I've heard them in was the Woden Victor - not a small enclosure.
Woden Design | Victor
Thanks again for your suggestion. I had a brief discussion with Scott about the Woden Victor. Unfortunately do not have WAF approval for its size for my room.
- More Vendors...
- Planet 10 hifi
- Metronome with FE166En
