I was intrigued by the sound differences between ECC83 tubes of different manufactures, even though on the cathometer they looked about the same, that is why I propose an indirect determination of the vacuum quality in the tubes by measuring anode current at a very low voltage. Worn tubes or with air in them give current values a hundred times higher than normal and smaller differences occur in tubes with different manufacturers, what do you think?
Valves with air in them affect the getter vapour on the glass inside.
If a valve is gassy, is will flashover at a much lower anode - cathode voltage and have poor thermionic emmission.
This is not what I think, this is a scientificly proven fact.
It may works, yes - at least to a certain extent : a tube which have a "soft vacuum" often offers a higher current than a "hard vacuum" tube, for the same parameters. Also, it is know since the early years of Radio that a "soft vacuum" is more sensitive than a "hard vacuum" tube, when used as a RF detector.
T
A 12Ax7 Eico tube has a measured anode current of 8nA and an ECC83 Tesla 34nA, clearly the American tube sounds better although the cathometer, gain factor and slope are comparable
For example, the Sodion tube.It may works, yes - at least to a certain extent : a tube which have a "soft vacuum" often offers a higher current than a "hard vacuum" tube, for the same parameters. Also, it is know since the early years of Radio that a "soft vacuum" is more sensitive than a "hard vacuum" tube, when used as a RF detector.
T
