I am building an amp that's going to go into an aluminum enclosure with a silver front panel. I have found nice silver knob for the volume but can't find suitable silver push button switch for the power. I do not want the toggle switch as it looks too industrial. I am looking for something like this:
push button
Unfortunately, all the switches similar to the one linked above were momentary switches.
Any ideas where to get SPST or SPDT switches like that? It doesn't have to have a LED.
Thanks.
push button
Thanks.
Not exactly the same, but close.
1241.6821.1120000 Schurter Pushbutton Switches
Mousers catalog page with other circular illuminated switches:
http://www.mouser.com/catalog/catalogUSD/644/1768.pdf
Thanks Jeffrey. I will bookmark those links for future use. For the amp I am assembling now, I have decided to put the switch in the back. But the buttons you have linked to are exactly what I was looking for.
There's plenty listed on eb*y from HK sellers, they're just a little hard to search for.
Here is a US source if you don't mind paying a little more.....
16mm Latching Bulgin Switches | Page 1 | Sort By: Product Title A-Z - FrozenCPU.com *
22mm-Latching Bulgin Style Switches | Page 1 | Sort By: Product Title A-Z - FrozenCPU.com *
I've bought a couple from them before and their service was good.
Might be the one you are after, but it will probably double the cost once you add in shipping 🙄 Altronics - Your One Stop Audio Visual & Electronics Supplier
Tony.
Tony.
And a momentary switch could be made into latching with a pretty basic litttle toggle circuit. The button circuit would control a relay or something.
I bought one of those switches (not momentary) from eBay a few months ago. just keep digging through the search results, the answer is there.I am looking for something like this:
push button
I dont like LCD's on my eqipment so I have used this in the past I think its the same parts code in the Farnell US store.. not sure
APEM|AV0830C940E|PUSHBUTTON SEC.SWITCH-RECESSED | CPC
Joined 2007
JINGHAN SWITCH have the metal pushbutton switch, The Metal Push button switch with LED type also have 220V.
I have a box full of push button switches.... they are the type you can put your own button onto. If you know someone who can machine a nice button to fit it would look good.
Let me know if you want one or two of them.
- Design & Build
- Parts
- Metal push button switch?
