Memphis St-16 500D
Im working on a Memphis St-16 500D I replaced the Power fets due to being toasted which were unreadable with the inf3205 just like what the st-1000D uses powered up the amp I felt confident that was the problem the red protect turns on right away and then itll dim then go bright in cycles any suggestion if it could be the Output fets or would you suggest checking the driver bjt's first 1266 ?
I will pull the driver board and retest the amp thanks perry im not sure what you mean by tabs the metal pcs above the output transistors casing? If so how do I test that? I used Dows Silicone put everything back together before testing and used kryptonite in between the heat sink where the insulator was badly burned and I had issues with the screws being seized so that's why I thought I would get suggestion before tearing everything back apart again for testing
I also tested the led separate and it lights up (grn) I found a couple BJT 1266 shorting so ill swap those out tomorrow as far as the led light goes im guessing another bad component I just don't know where. Correct me if im wrong when the driver board is disconnected out of the amp and powered the green light (power) Should still be lit
Sorry I have passing current as in cont. throughout all transistor tabs ill check for volts with the amp disconnected also I noticed when I run the +/- wire the red protect light blinks for one second before I connect the jumper wire to the remote turn on
