Have a Memphis 16-MCD1000 that works but with lots of noise.
3 output filter capacitors are damaged.
2 domed electrolytics and 1 burnt film cap.
The electrolytics are 33uF@200v 105C non polar 26mm x18mm. (Samwah)
Any recommendation as to brand and series for this part?
The film cap is a marked 225K100 MMY .
It's a blue box cap made by Yuchang.
By the markings a 2.2uF@100volts.
Problem is it is only 13x11x5mm, way too small for 2.2uF!
Is this some non-standard code?
I haven't found a source for the 33uf NP caps. I've been replacing them with 10uf Mylar/polyester capacitors and haven't had a problem.
The 2.2uf (C240?) is only rated for 100v so it's not going to be as large as a 250v cap.
