Medium power Class D battery bass guitar amp
A friend of mine has been asking about a light portable bass amp that he can lug with him and use for around 4 hours. I want to build this as a christmas present.
So far I have come up with the following:
Using 4x 60W/hr 6 cell notebook batteries for the supply
Using 1x 60W/hr 6 cell notebook battery as a reserve supply (switchable)
Using a 45-55 litre max fibreglass enclosure with a 10" driver and 4" mid
Using 2x 41hz.com Amp 11 (60w RMS@32V) (one for a switchable backup with a 2 ohm resistor in series with the speaker as a "limp mode" backup).
I know this will not blow the house down, but with a speaker around 92db 1w 1m am I safe to assume it will be quite loud? Also it has to have bass extension to 41.2hz.
Can anyone suggest a suitable speaker? Is there anything that screams failure in this project?
Are the 41hz amplifiers up to this task, if someone unplugs a guitar and it makes a high level pop sound will the ampifier take it? Should I add input protection (such as 2 lots of opposed polarity banks of 3x diodes in series to clamp the input level)
Thank you for your help with this.
Intended Application
He does a bit of street performing. I do see what you are getting at and my choice in woofer would be:
http://www.eminence.com/pdf/legend-bp102-4.pdf
If required I will use 2x 41hz AMP11 with two of these speakers, I may use mild equalisation to bring the bottom end up (3db centred at 60hz). If I use 2 amplifiers and speakers I will be using 6x 6 cell liion (from 60W/hr notebook packs) for 360W/hr energy storage capacity.
At the moment I am seeking advice with regards to the sound output level and speaker selection - I haven't had to build a bass guitar speaker before, Would using a sensitive 4R home hifi woofer / car subwoofer be better at the expense of a small degradation of sound quality?
This is a bit of an oxymoron.
A good bass combo is heavy and large.
This looks like a good (cheap) battery: DealExtreme: $12.70 Mystery 11.1V 2200mAh Lithium Polymer Rechargeable Battery
I haven't tried this battery, but I have bought other lithium batteries from DX with no problem. The Amp 11 will be OK with 3 of these if you get the version with 50V caps (#28)
You've also got a charging problem. You might want to look at something like this balancing charger: Inwood Models : LIPRO QUAD 6 BALANCER CHARGER [FCH005] - £109.99
...you'll need some switching to break the battery down into 3 individual packs unless you can find a charger that will cope with them in series. I think the pack shown has connections for charge balancing, but this is something you need to check. You can probably source a charger closer to home, electric flight is the source for this one.
I'd go for a more efficient speaker, I see some Celestions out there with 99dB, this is more than twice as loud, or the same volume for less power, which is a significant consideration.
Fibreglass may be light but you'll probably find it easier to construct a resonance free cabinet with MDF.
w
Your friend is probably thinking of the classic small bass combos like the Gallien-Krueger MB150 or some of the Genz-Benz stuff. I suspect both makers use proprietary drivers to get things so ridiculously small, but maybe you can find some info on the driver used in the MB150 over the years-- it has a strong cult following.
