I have been building a pair of three way unity horn's which I am running tri-amped with an active crossover and three separate amplifiers. I would like to measure the sensitivity for each speaker as a whole but am unsure how to correctly do this with three separate amplifiers driving different frequency bands.
All three frequency bands have a total of 8ohms (the low and mid bands use 4 woofers and 4 mid range drivers wired series-parallel to give 8ohms total; the high band uses a single 8 ohm compression driver)
To obtain a sensitivity measurement of x dB / W, if I use the standard measurement of 2.82V for each amplifier, then the speaker as a whole will be drawing 3W of power in total which is not correct. Should I use 1/3 W for each frequency band (i.e. running pink noise with 1.63V from each amplifier) or is it not as simple as that?
There really is no such thing as a whole speaker sensitivity in a triamped active setup. Measure each driver at 2.83v and you have it's sensitivity. If you wanted to know what the sensitivity would be as a passive xo, single amp speaker, then it would be about equal to the lowest sensitivity driver. If you think through adding additional drivers as in a single amp/passive speaker, then current will go up as you feed frequencies covered by more than one driver, but voltage will not. Hope that makes sense.
Thanks for that, makes sense. Yeah I was considering it as though it was a single amp / passive xo setup. It also explains why I haven’t seen anybody talking about whole speaker sensitivity for multi-amped setups!
