measuring output transformer inductance?
If you use a standard 1vac @ 120 Hz inductance bridge with a SE opt you should know how much DC current the transformer is designed for.
Actual working inductance, with 20 to 40 ma flowing through an appropriate gap, will be approximately twice the rest value (1 vac @ 120 Hz is a rest condition for OPT's. For a PP OPT you can count on about 10 times of this rest inductance.
If the SE OPT is designed for even higher current, 60 to 180 ma, the gap will keep the working inductance to about 1.3 times the rest voltage. Larger gaps than this (physical gap of .015 for E/I or .030 for C Core) and currents out to 320 ma DC, will give a flat inductance out to saturation, from rest conditions.
Bud
