measuring JFETs IDss
So I saw this post from Mr Pass
Get a 5 to 13 volt supply and a DC voltmeter. Connect the +V to the
Drain, connect the Gate and Source together to a 100 ohm resistor,
and connect the other lead of the resistor to ground.
Measure the voltage across the resistor, which gives the Idss. 1 volt
= 10 mA of current.
Try to measure all devices under the same conditions, temperature,
and duration of test.
I'm assuming this is for N-channel and to test for P-channel, I just need to reverse power supply polarity. Am I right?
Yes
Some FETs may have a high Idss and testing that could over-dissipate the device if the testing takes too long to do. In that case, the test would be done using a short duration on-time pulse and capturing the resultant current across, say, a sense resistor, on a scope.
