The generator provides the signal fronts 5ns. Has an amplitude control of the output signal. Switch for 8 frequencies of signal generation, 100Hz, 300Hz, 1KHz, 3KHz, 10KHz, 30KHz, 100KHz and 300KHz.
The output voltage range is adjustable smoothly from 2 to 10 V (without load) at the OUT and from 0.2 to 1 V on the OUT /10.
The output impedance of OUT and OUT / 10 outputs is 120 and 100 Ohm.
Minimum output load impedance OUT - 200 Ohm; The supply voltage is 12 ... 18 V; Consumed current - no more than 20 mA.
1pcs - USD$67
Shipping cost on request
dm
1pcs - USD$67
dm
