Mean hissing (and static) in 2 Watt Class-D
I'm hoping for some suggestions here. I have the following:
-2 Watt Class-D Amplifier Vcc 2.5-5.5V
-2" Fullrange Driver
Now when I connect it all up, there is a heck of a lot of funny noise kinda like hissing, simply annoying. It does not really give much output, but that I was expecting.
The hissing stops when I unplug the source. (Checked with two notebooks (on/off mains), Tv-set headphone out, and battery-powered MP3-player). Also there is not really a difference whether the amp is run off battery or ac-converter. At 6 V (4xAA) it is much worse than at 4.5 or 3V ( I suppose that's because I am at the high end of the specified input range).
The thing has differential and single ended inputs. I suppose I would use single ended in the application with an MP3-Player, right? I checked single ended (GND to GND), differential (GND from the player to In-, signal to In+) and something inbetween (GND to In- and GND, signal to In+) but that did not change much either...
Anybody have an idea how I could get that thing a little less annoying, and a little more music-making?
Or should I just write the things off as "learning-money"? I guess the static it outputs all the time is normal. I would be cool with that, if the hissing was gone. I'll try to write sureelectronics about it also, but reading the answers on their page, I kinda doubt that would be too helpful... Maybe they'll swap the two sets for a TA2024 😛
Although I really want to drive the whole setup with 3-4 AAs.
I just found these amps so darn cute, and wanted to fabricate a birthday project for a friend, but I guess he'll have to wait (or the budget will be way higher than planned).
Thanks for your input
P.S.: Once I get done, I'll post the project here 😉
Ok, so Sure emails me that the amplifier simply makes that much noise out of nothing. They refunded me however. Awesome service!
Now I've got a whoopin' 8 bucks to spend on some other small amp!
I want it to be powered by (max) 4 AA batteries. Anyone know of anything out there? National Semiconductors has a nice class-d thing, but I think it's smd and also not available anywhere.
I've read something about lm368, but I can't find much more info on that one either. Also I don't have any sources, but I guess I would manage to find some.
Google doesn't really get me anywhere, I get a whole lot 12v amps :/ Simply no room for that!
I would appreciate some chips thrown at me, preferrably without much external circuitry!
Robin
P.S.: I got to keep the amps, so maybe someone still has a hint how to quiet them down. They are frikkin' perfect for what I want, except for the funny noises they produce...
