I have to replace the transistors in a MC2300 driver boards. I think that these boards are the same as many Mc amps
I know that the drivers Q112-114 are 2N5320 and 2N5322
But what are the Q108-Q110 and Q102-Q104
Do someone has an idea about the original parts numbers or replacement parts numbers that have the same characteristics as original parts
Hi legarem,
Can you post the original part numbers for these (the house numbers)? I'll have a look.
Sorry, I don't have the manual for that one.
-Chris
-Chris
Hi Chris
Here are the Mcintosh part numbers
Q107-Q108 are 132-021
Q109-Q110 are 132-032
Q101-Q102-Q103-Q104 are 132-032
Drivers which I think are 2N5320 and 2N5322
Q111-Q112 are 132-038
Q113-Q114 are 132-039
Thanks a lot
Marc
Thanks a lot
Marc
Hi Marc,
132-021 ->132-171 (MPSA05) 132-032 -> 132-172 (MPSA55) 132-038 -> 132-153 (2N5320) 132-039 -> 132-154 (2N5322)
From the industry numbers you should be able to replace these easily. If you use NTE or ECG I will not talk to you again. The semi police will come and smack you as well! 😉
Why are you changing all of them??
-Chris
-Chris
Chris
The amplifier was in a bar and was badly repaired. It has many burned resistors. All transistors were changed on boards and are not the same from one channel to the other one.
I bought 30 (real) Motorola MJ15003 and matched them for outputs. Don't worry. i don't plan to buy NTE junk.
it seems that 2N5322 and 2N5320 can't be found now. Any substitution recommended ?
A last question. What's the transistor # for Mcintosh part # 132-515
Thanks a lot
Best Regards
Marc
Thanks a lot
Best Regards
Marc
Hi Marc,
A bar amp. Standard hack service too. It never ceases to amaze me the things bar owners will run with, and the hackers they will employ.
You have your work cut out for you then. 132-515 ->132-028 (2N3738: 120V, 50mA)
The others might be replaced by 2N3440 and 2N5415. If you can't get those, another case style is needed. The originals Vceo 90V, 100mA, gain around 40. Dissipation around 10W on the heatsink.
I guess step one was clean, clean and clean.
-Chris
-Chris
Hi Chris
One last I forgot to ask
Mcintosh part # 132-031
2N5320 and 2N5322 seems like TIP 41C and TIP 42C
Do you recommend me these parts ?
Thanks again
Marc
Thanks again
Marc
I made a little error
2N5320 and 2N5322 seems like TIP 3C and TIP 32C
not TIP 41C and TIP42C as written in my last message
Marc
Marc
Hi Marc,
Correct me if I'm wrong, but the original parts were TO-5 or TO-39 case styled parts. How did you arrive at TIP 41/42 or 31/32 types (TO-220) ?
What cross reference did you use?
-Chris
-Chris
Hi Chris
I know that TIP31C and TIP32C are TO220 but electrically, they appears to be near 2N5320 and 2N5322. If you think that they can do a great job, I'll use them.
Please, don't forget to give me the substitute for Mcintosh part # 132-031
Cleaning is done (a lot of job) and Output replacement is also done.
I plan to turn on the beast during next weekend
Thanks again
Marc
Thanks again
Marc
hi guys,
I am also after a few transistors but for a mcintosh mc2105 amplifier.
I was wondering if you guys know the transistor part numbers for the following:
132-054
132-541
132-542
Thanks. my first post on this forum 😀
132-054
132-541
132-542
I've always had good luck with the parts people at McIntosh. They will usually tell you the cross numbers and replacements for obsolete numbers. Prices are a little higher but at least you know the parts will work. Give 'em a call. Do you need a schematic? I think I have the service manual on that one.
Craig
Craig
Awesome! Could you give me the contact details you use for the Mcintosh people. Oh and I already have the schematic. Thanks
Asif
Asif
Damn they dont have the parts.
Am planning to clone a Mcintosh MC2KW amp its retail price I think is £14,000. If I can get the parts I pretty much will be able to make the amp for free. At the bottom of the MC2KW schematic it has the part number list, I was wondering if any of you knew how to translate the mcintosh part numbers into the original transistor numbers. Its been a real headache for me for the last week. Ive been struggling to clone any of the mcintosh amps. The resistors and capacitors, are no issue but the transistors are a major headache. please help!
thanks.
Asif.
thanks.
Asif.
MC2105 preamp board repairs
I have been flowing this thread. The MC2300 sounds like it uses the same or very similar board (at least using the same part numbers) as the MC2105. I have traced my problem to transistors 132-021 and 132-032. the first is a 2n3738, but what is the replacement for 132-032? I think you said 2sa970bl, but I want to be sure before replacing it.
This unit also looks like it did bar duty, not so much smoke damage, but a lot of dust and a hack repair with lots of wrong parts in the final output section.
Thanks in advance,
Steven M.
Thanks in advance,
Steven M.
- Mcintosh Mc2300 driver boards transistors
