Is this normal for this power amp? When I crank up the volume the meter lamps dim a faint bit. Should I have the amp checked out by a technician?
Slight loss of voltage not enough to stop them working just dim but replacement bulbs are cheap try that first before any deeper analysis .
Thanx!
Thanx a lot! I couldn’t decide whether to put this beast on a separate 125v 20 amp circuit as well.
