Maximum power in WinISD
HI all,
So Im currently in the process of designing a subwoofer using 2x DSA215 PR's and 1x SB23MFCL-4 although almost finished I had one last question:
Is the maximum power in WinISD only looking at Xmax without any filter?
Since due to exceeding Xmax I will have to use a High Pass filter at 26 Hz but turning this on and off does not reflect in a change of the maximum power graph. With the filter Im way below Xmax (both for the PRs as the driver) when the signal input is on 150 Watt.
