material to cover guitar amplifier cabinet
They make a very thin carpet material that is frequently used to cover guitar speaker and PA cabinets. Also, frequently used for car Subwoofer cabinets.
These photos might not help much, but should give you some idea.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-765
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-764
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-768
And here is what the cabinet looks like when it is covered -
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=269-975
This is a very thin indoor-outdoor carpet and is frequently sold for automotive applications.
The only difficult area is the corners, so it is best to cover the corners with corner guards similar to this -
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=262-836
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=262-152
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=262-150
I would assume similar products, both carpet and corners, should be available in Mumbai.
The alternative is to cover the speakers in vinyl leather-like material. The better quality vinyl, the more durable it will be.
The final alternative is to simply give them a good heavy coat of flat black, gray, or charcoal colored paint. I would suspect a 'plastic', epoxy, poly based paint would be the most durable.
Just a few thoughts.
Steve/bluewizard
