I acquired a set of transformers which can be used with either a Matchless Spitfire or Lightning. Does anyone have experience with these amps? Any suggestions on which one to build? Thanks.
I have a copy of the Matchless Lightning with updated NOS Matchless OT's from West Labs..it is a good amp for sure, does great el-84 cleans..& does a wonderfull dirty..I use it for the cleans though, which are very good..Mine has a pentode/triode switch also..Were did you get the trannie set...?
I got a West Labs set also. Ive had them forever, just can't get around to all my projects. LOL.
A pentode / triode switch is a great idea also! Would you share the schematic?
I would if I could, Ed Giller built this amp for me a couple years ago, I did the trannie update, but that is all I have, I could hand write one out for you from what I have, but it would take some time..But could be done if you want.
If you head over to www.18watt.com or www.ax84.com and post the same question there, you should get LOADS of answers to this one.
