Hello,
is it essential to match the mosfet (IRFP140) to divices in another channel, Or can I use unmatched divices?
Is the IRF044 the better choise?
Günter
Günter
The 044 is a bit better.
Unmatched is fine. I match mine anyway, for the
same reason that my left and right speaker cables
are the same length and type. 🙂
Nelson,
I'm using the 044n in my Zen. I have read here that the 044 w/ the "n" designation is not good for audio. Do you know anything about this?
Vince
Vince
I am not aware of any 044N as such. There is a letter
which appears to be part of the lot code, and I have a batch
of these with the "M", but I don't think there's anything
to it.
By they way, we are intending to make these available
in matched sets on passdiy.com for the 900 or so that
I have.
to it.
I have.
An hour later:
I looked them up, and there is indeed an 044N, and
the N apparently stands for "new" 🙂
It is not the same part after all, with the biggest
alteration being a reduction in wattage rating
to 100 watts down from 180 and a lower Rds
from .028 to .02
Beyond that, I don't know whether they sound
better or worse, my only experience being with
044's. I wouldn't hesitate to try them out,
however.
from .028 to .02
however.
It's just that some persons on this forum have said these are better for switching rather then amplification.
My Zen sounds fine. I have 10 of these and will probably build 4 mini-alephs.
Thanks for the reply.
Digi-Key Part Number IRFP044N-ND
Manufacturer Part Number IRFP044N
Description HEXFET 55V .024 RDS TO-247
Standard Package 25
Standard Package 25
